Help with heat
Old Dec 30, 2011 | 07:44 AM
Toyman's Avatar
Toyman
Default Help with heat
My problem is that prob 90% of the time it blows lukewarm air and 10% of the time it has the normal hot air, blowers are working fine, thought if it was heater core bad it would blow cool/lukewarm all the time? Also the temp control is working fine so im guessing the blend doors are working also. 2003 Dodge Ram 1500
Old Dec 30, 2011 | 08:12 AM
MikeHTally's Avatar
MikeHTally
Sounds like the blend door. The temp control doesn't control air direction. The door is probably allowing too much outside air in.
