How long do Universals last?
Old Aug 3, 2005 | 05:02 PM
Silverquad02's Avatar
Silverquad02
Default How long do Universals last?
Ok...I have a 2002 quad cab 4x4 with the 4.7L. It's 57k miles and my forward universal is shot. Just wondering if anyone else has had to replace it on their Ram.
I do mostly city driving and the only off roading I do is on a few un-improved roads around the Detroit area. Granted I drive a bit rough but my old '97 went well over 100k with me never needing the universal replaced...and I off-roaded that beast and trailered a boat.
Anyways...just curious...
Old Aug 3, 2005 | 05:23 PM
Lateral-G's Avatar
Lateral-G
Default RE: How long do Universals last?
57K seems awful low mileage for a U-joint to go out. Could be a bad bearing or lack of lubrication. Did you lift the truck any? Lifts are known to be hard on U-Joints. Also jack rabbit starts where you suddenly put a lot of torque on the joint. However, even with that you should get more than 57K miles. Could just be a one of a kind thing with that particular joint.
-G-
Old Aug 3, 2005 | 06:16 PM
Drew's Avatar
Drew
theres a similar problem with the 2500's and their u-joints going early in life.
but just like anything, you can get a defective unit, or have one that lasts 5 million miles and shows zero wear
