Gen 3 Ram Cummins and Transmissions
Were the transmissions supplied with the Gen 3 Rams & Cummins all the same? I am considering a Gen 3 vintage Ram with a Cummins for a plow truck and have heard from more than one Ram/Cummins owner that they have had trans problems which required either re-build or replacement. Could someone offer an experienced opinion(s) of their own? I don't want to make a decision that I will be sorry for.
make sure trans is serviced properly ,then install the biggest trans cooler you can find.[an external filter is not a bad idea too].change the filter and fluid every year and you should not have any problems.by the way i drive a06 2wd diesel.
