Fuel Level Issues
Old Jan 7, 2012 | 04:24 PM
geordiep's Avatar
geordiep
Default Fuel Level Issues
My truck is running out of fuel well before it reaches empty. When I first bought it (3 years ago), it would run out of fuel around the 1/8 fuel level. Now that I have done an engine swap it is now running out around 3/8 fuel level. Don't know why the change now?
I know the float is accurate since the amount of fuel was only 64 liters on the last fill (after running out at 3/8 tank).
I have a service manual and am assuming I need to remove the Fuel Pump Module to see what the issue is. It states I need a special spanner wrench #6856 to remove the module. The tool is $75 (google search). Is there an alternative? Or should I be looking elsewhere for a solution?
(I have attached a PDF of the Fuel Pump Module section of the service manual.)
Thanks
Old Jan 7, 2012 | 04:42 PM
dirtydog's Avatar
dirtydog
Moderate User
I've always used a screwdriver and a hammer to remove the cap. Gotta becareful not to chew it up though!
Maybe your float is getting stuck? Have you noticed your gas guage staying at that 3/8th's mark for longer than usual before running out of fuel?
Your sending unit could be bad as well with it's readings below 3/8ths of the tank.
Old Jan 7, 2012 | 04:46 PM
geordiep's Avatar
geordiep
Is the module an all-in-one piece with the inlet/suction hose encased to the module?
I don't want to tear it all apart only to find I have to replace the whole thing. If so I will find a replacement at the junkers first.
To remove Fuel Pump Module:
Using search on this forum found suggestions of using a large channel lock pliers or a dull screw driver and hammer off the module. (https://dodgeforum.com/forum/3rd-gen...-assy-out.html)
Old Jan 7, 2012 | 04:51 PM
geordiep's Avatar
geordiep
Is the float only used for fuel level readings? Or does it also effect where the fuel is sucked from inside the tank?
I know for a fact there is still fuel in the tank when running out of fuel, simply because upon refueling it takes far less then the tank size of 95 liters.
Old Jan 7, 2012 | 04:58 PM
dirtydog's Avatar
dirtydog
Moderate User
I believe the sending unit, float, filter and pump is all one unit.
Old Jan 7, 2012 | 05:09 PM
geordiep's Avatar
geordiep
Looks like I might have to find a replacement module from wreckers and simply swap it out.
I could live with it when EMPTY was at 1/8. But 3/8 does not give my much fuel. Major pain especially when I only get 10mpg. I need to carry a gerry can with fuel just to be safe.
Thanks for input.
Old Jan 7, 2012 | 05:24 PM
NoLimitzR1's Avatar
NoLimitzR1
Rockauto i believe sells fuel tank with pump n all for 188.00 if i recall, get it all new
