Leveling kit for 2007 ram 1500 2wd???
Old Jan 9, 2012 | 12:59 AM
Kelley2011's Avatar
Kelley2011
Default Leveling kit for 2007 ram 1500 2wd???
need some advise/help on finding a leveling kit for my '07 ram 1500 2wd. ive been reading other post and have found out a little bit of what i need but i would like some further info on what exaxctly i need?
Old Jan 9, 2012 | 08:26 AM
08HEMI1500's Avatar
08HEMI1500
You can either get a coil spacer, 3 inch longer coil springs or a 3 in longer spindle. The longer coil or spindle will make you more level than the spacer will
Old Jan 9, 2012 | 09:30 AM
Brandon Anderson's Avatar
Brandon Anderson
Good lord this has been beaten half to death...
3" springs will not work on a '06+. Max you can fit is 2" coils or coil spacers without wrecking your UCA and coil bucket. 3" spindle is your best bet.
Old Jan 9, 2012 | 10:10 AM
08HEMI1500's Avatar
08HEMI1500
Not even half, its full on dead lol
Old Jan 9, 2012 | 02:39 PM
Kelley2011's Avatar
Kelley2011
What would adding a 2.5" coil spacer do to it? Would it be worth the time money and work?
Old Jan 9, 2012 | 04:20 PM
08HEMI1500's Avatar
08HEMI1500
It will essentially make your coil longer. It's like basically putting a hockey puck on top of the coil. It's cheap and easy to do but you always get what you pay for so the spindles are the best way to go like Brandon said
Old Jan 9, 2012 | 05:45 PM
Kelley2011's Avatar
Kelley2011
Where would the best place to buy a spindle be?
Old Jan 9, 2012 | 06:00 PM
08HEMI1500's Avatar
08HEMI1500
airbagit.com
Old Jan 9, 2012 | 08:54 PM
Kelley2011's Avatar
Kelley2011
I'm goin to go with the coil spacers and I'll post pics later
Old Jan 9, 2012 | 11:14 PM
Brandon Anderson
That will make your UCA slam into your coil bucket during articulation. 2" max for the '06+ 4x2. Even at 2", the UCA will hit on harsh bumps.
