Fog light connector
Old Jan 10, 2012 | 07:34 AM
Deroneill's Avatar
Deroneill
Default Fog light connector
I replaced my fog light bulbs with a halogen 80W bulb. I have a problem with these new bulbs generating too much heat and they are melting the plastic connector but not the wires. I tried replacing the connector with an aftermarket one with i bigger guage in wire but its still melting at the connector. I was wondering if anyone knew of any suggestios as to how i can fix this problem. It would be great if i could find a connector harnesss made out of the same material as the halogen bulb connector but im having no luck at the local auto parts stores??
Old Jan 10, 2012 | 08:16 AM
Lifttruck's Avatar
Lifttruck
Not to be a smarta$$ but use the proper replacement bulb would be my suggestion. Aside from that I would imagine that the wise thing to do if you need a brighter foglamp would be to somehow cobble mounts together and replace the stock units with similar sized aftermarket ones.
Old Jan 11, 2012 | 01:11 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I also recommend going back to the original bulb. If you want something brighter then get an HID kit
Old Jan 11, 2012 | 11:58 PM
Deroneill's Avatar
Deroneill
Thanks guys but those HID kits seem like such a pain to deal with. I'm gonna try a lower wattage bulb and if that doesn't work then I'll break down and buy the HID kit that I have to pay to modify. Do they sell a plug and play kit that I wouldn't have to modify for my truck?
Old Jan 12, 2012 | 12:28 AM
06Dak4.7Silver's Avatar
06Dak4.7Silver
http://www.ebay.com/itm/xeno-HID-KIT...item4ab156604c
$32 shipped. plug in the ballast, and plug in the bulb. the fog lights are easy to hook up HID kits to! headlights..not so much
Old Jan 12, 2012 | 12:39 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
^^^ Nice find. Headlights are easy to but you just need these with the headlight its
http://www.ebay.com/itm/140637518824...#ht_2808wt_952
Old Jan 13, 2012 | 03:48 PM
Deroneill's Avatar
Deroneill
Thanks weedahoe that's exactly what I've been looking for!
Old Jan 13, 2012 | 03:53 PM
06Dak4.7Silver
Thats a similar harness that I got from a local audio shop..their solution to Ram HID problems haha. I however have a Dakota but its basically the same PITA CANBUS operated headlight system
Old Jan 14, 2012 | 09:01 AM
Deroneill's Avatar
Deroneill
But do I still need to get relay harnesses or anything or does that come with the HID kit?... If I do even need it
Old Jan 14, 2012 | 10:10 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Harness and resistors for the fogs? No.
Harness and resistors for the headlights? Yes
We have a dedicated HID sticky thread BTW.
