The dreaded 04/05 Hemi Stall. Help please.
Old Jan 11, 2012 | 01:51 PM
crash83's Avatar
crash83
They didn't charge me anything..actually.
They even replaced a few sensors and did the flash upgrade and didn't charge me.
Old Jan 11, 2012 | 07:28 PM
beefchips's Avatar
beefchips
Was it under warranty or something? How did you convince them that there was even an issue? Were you lucky enough to have it happen when they went on a test drive?
Old Mar 20, 2021 | 01:00 PM
rrsnotyours's Avatar
rrsnotyours
Originally Posted by beefchips
First of all hi, long time listener first time caller.
So I've had my 2004 Ram SLT Hemi 5.7L since 2004. For the first 50,000 miles there were about 4-5 times I can recall experiencing the "slow stall", where the engine basically shuts down as though a light switch was flipped to turn it off. All of the sudden though it's happened 4 times in the last 4 months. You can look here to see some other examples of the issue.
Here are the symptoms (which I think are pretty well known to members of this forum by now)
1. No check engine light.
2. No codes.
3. Typically starts right back up.
4. When it happens it (to the best of my recollection anyway) happens right after I fill up the tank from empty. (I think this is a key symptom).
5. It doesn't always happen when I fill up the tank (as evidenced by the infrequent occurrence).
6. When it happens it is when I hit the brakes hard at a slow speed to taking a sharp turn at a slow speed.
It is very unsafe because I lose all brakes and steering. The worst instance was a few days ago as I was merging onto the interstate during morning rush hour. This was also the first time that the truck didn't immediately start back up, which concerns me even more. I would normally just throw it into N and start it up but ended up having to go into park and turning it over 4-5 times before it finally started.
I've gone to the dealer and had them flash the PCM and brought the TSP to their attention. That was a couple months ago and today is the first time it stalled again.
Has this issue ever been definitively resolved? I think the fact that it happens right after filling up the gas tank has to be a huge clue but I can't figure out what it's telling me.
I've got to figure this out because it's very unsafe and I'm losing faith in this truck now. Ideas? Soultions?
Thanks!
Ok..I have a '04 Ram 5.7....Ive dealt with EXACT same issue...TWICE since owned truck...both were different problems and so dangerous I almost sold truck.
1st time....fuel pump...was still activating but faulting randomly...usually thought pumps just died....harder to figure out than ...
2nd time....EASY!!! crankshaft sensor...5 minute swap...so both times felt the same....truck was stalling at idle...stalling while driving...just whenever TF it felt like it...went completely dead..then started back up...starting got more difficult and took a few tries eventually. Also known remedy is the throttle body and sensor....should get the bolt in parenthesis light on dash if case. Hope helps anyone!
