front end wobble when 4WD engaged with spacers
Old Jan 13, 2012 | 12:11 AM
vikingdiesel's Avatar
vikingdiesel
Default front end wobble when 4WD engaged with spacers
First snow storm of the year and I turn 4WD ON and I get front end wobble ONLY when I give it gas at low speeds but the wobble goes away after a few seconds, its definitely time to ditch the 1.5" spacers but hopefully the tires clear which is should considering they are 11.3" but they do have an aggressive sidewall, anyone else experience this with the spacers with 4WD on?
Old Jan 13, 2012 | 04:38 AM
NoLimitzR1's Avatar
NoLimitzR1
Hubcentric spacers?
Old Jan 13, 2012 | 11:14 AM
vikingdiesel
Yes hub centric
Old Jan 13, 2012 | 09:13 PM
NoLimitzR1's Avatar
NoLimitzR1
If you decide to ditchem, I maybe able throw few bucks your way for them
Old Jan 13, 2012 | 11:56 PM
vikingdiesel
Im keeping them, i have to, my tires wont clear
Old Jan 14, 2012 | 03:42 AM
NoLimitzR1's Avatar
NoLimitzR1
Try to find a roadforce balance machine and have wheels n tires checked.
Old Jan 14, 2012 | 11:48 AM
rhendrix's Avatar
rhendrix
Could it be hub bearings or cv shaft? Wouldn't think hub bearings since it only happens with 4wd on. but you never know.
Old Jan 15, 2012 | 01:30 AM
vikingdiesel
bearings are new with less than 5k, cv shaft........ maybe? but even that looks good
Old Jan 15, 2012 | 11:15 PM
rhendrix's Avatar
rhendrix
Jacked it up and checked for play yet? If it's not the cv shaft it could be a ball joint issue, but it'd be highly unlikely since it only happens whenever you engage 4wd.
Old Jan 20, 2012 | 12:49 AM
vikingdiesel
its all fine, it was checked a few days ago
