P0441 Evaporative Emission Control Incorrect Purge Flow
Old Aug 5, 2005 | 02:22 AM
dcmcclung's Avatar
dcmcclung
Default P0441 Evaporative Emission Control Incorrect Purge Flow
I keep getting a malfunction indicator light when the gas tank gets half full. When I check the code it comes up as P0441. I reset the light and code but it returns once the tank gets half full again. Since I live in a state that does not check emission control, is this something that I need to be concerned with? Will any permanent engine damage occur if I ignore this particular code?
Any help or ideas would be appreciated. Thanks.
Old Aug 5, 2005 | 04:44 PM
1SlowFormula's Avatar
1SlowFormula
Default RE: P0441 Evaporative Emission Control Incorrect Purge Flow
What year is your truck? I have heard that '03 and earlier have a maunfacturer of the gas cap used incorrectly finished metal diaphragms that permitted premature corrosion.. You can read it here
Old Aug 6, 2005 | 04:53 PM
dcmcclung's Avatar
dcmcclung
I have a 2002. Thanks for the info.
