Which leveling kit to go with?
Yep, basically you need to measure your ground to top of wheel well (or center of hub to wheel well), get the weight off the front of the truck and crank the bolts a few turns, drop the truck - remeasure and adjust each side as necessary.
Remember you may need longer front shocks and should get an alignment when leveling the front...
Trending Topics
difference?
What's the difference between turning the keys and adding 1" taller shocks, installing an aftermarket leveling kit and installing a 2" "lift kit?"
Will turning the keys or adding a leveling kit affect the warranty? I have a factory, lifetime, bumper to bumper warranty. (08 2500)
So what are my options? Are all leveling kits " the same?" Will some "ride" better than others? Any front end issues with installing a leveling kit-shimming, etc...
Any other brand recommendations, besides Arctodus' Hell Bent Steel endorsement?
Also, like C-Ram asked, any reputable place to order a leveling kit? Does the factory make/install a leveling kit?
Thanks for the patience with all the questions...
