Throttle body spacer?
Old Jan 17, 2012 | 06:21 PM
Customcowboy's Avatar
Customcowboy
Default Throttle body spacer?
07 Ram 4.7lt-flex (with MOPAR Cold Air intake)
is the throttle body spacer worth adding? and will it work with the cold air intake?
Old Jan 17, 2012 | 06:45 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
It will work with the CAI but you will get zero benefits from it..its a paperweight on a fuel injected motor
Old Jan 17, 2012 | 06:59 PM
Customcowboy
then why is there such a hype over it?
Old Jan 17, 2012 | 08:16 PM
HammerZ71's Avatar
HammerZ71
And just where are you seeing hype? Car magazines from 1992?
Modern fuel injectors atomize the fuel unlike Carbs which relied on suction created by air traveling through the intake to draw fuel.
Besides, 3rd Gens like about every engine designed since the mid 90's have the injectors on the fuel rail - WAY after ANY benefit from a throttle body spacer would be realized.
But if you really want one, they do create a cool sounding whistle when air passes through them...
Old Jan 18, 2012 | 01:02 AM
John  M's Avatar
John M
I never understood the concept behind TB spacers either. If it would have benefited, wouldn't they have made the TB an inch deeper to start with?
On the old GM TBI engines, the "dog bowl" (Hypertech Powercharger) aftermarket piece made a very noticeable gain in off-idle torque. That's because fuel and air mixed right there, like a carb, and not a foot inside the intake tract. I'll bet that low-tech lump made far more power below 2k rpm than my Hemi does. After that it isn't a contest
Old Jan 18, 2012 | 07:41 PM
davb673's Avatar
davb673
Because they are easy to make, and easy to install. People that produce them don't care if it helps, as long as they can get your money...
Search around on DodgeForum, you can find answers to most any question you come up with. Besides, you will likely find the answer faster than you would by waiting for folks to answer the question. -->Save your money for something that is proven to help.
Welcome to DF.
