03 Ram help
Old Aug 6, 2005 | 05:51 PM
JTugwell's Avatar
JTugwell
Default 03 Ram help
i have a 03 ram 1500 with stock 20" wheels and tires. when i turn the truck i hear a rubbing sound coming from the back of the truck. has anybody had this problem?
Old Aug 6, 2005 | 11:07 PM
Andy4.7's Avatar
Andy4.7
Default RE: 03 Ram help
What do you mean exactly by rubbing sound?
Old Aug 6, 2005 | 11:54 PM
JTugwell's Avatar
JTugwell
it almost sounds like the tires are rubbing in the fender well. it happens at slow speeds like when parking and only when the wheel is turned. i know its not coming from the front. but i have no idea what it could be
Old Aug 7, 2005 | 12:09 AM
Andy4.7's Avatar
Andy4.7
I see
Do you think it could be comming from the differential? Sometimes if you have the limited slip it can make some noise when turning if it doesn't have the LSD additive in the rear end, I think thats more of a clunking type noise though. What about the brakes, they could be sticking...
Assuming the tires aren't actually rubbing, those are about the only two things I could think of. It's hard to really say without hearing it in person.
Old Aug 19, 2005 | 04:20 PM
MIKESAPP's Avatar
MIKESAPP
I have an '03 1500 QC 4x4 w/ 4.7L with 265/17's and the same thing happens with my truck. If you go slow and turn the wheel hard you get a strange deep pitch squeak (like a headboard[8D]) with each rotation of the tire? I have the "anti-spin" differential which still has the original fluid, so it is not missing anything? Does that mean I need a fluid change?
Old Aug 19, 2005 | 04:36 PM
Hemi_Chris's Avatar
Hemi_Chris
There is a clip in the differential that can detach and fall into the gears, trashing the entire rear end. One symptom is that fluid will begin to leak from the pinion seal. Have a shop or dealer check the rear diff thoroughly.
This happened to me and my local dealer replaced the entire unit.
Old Aug 19, 2005 | 05:49 PM
osteodoc08's Avatar
osteodoc08
I'd check the e-brake first. Then I'd look at the diff.
