"Lights behind grille" brackets?
Old Feb 2, 2012 | 09:29 PM
C-RAM's Avatar
C-RAM
Default "Lights behind grille" brackets?
On some website I found brackets that bolt down to the radiator support bolts (the pair left and right) to mount aux lights. Now I can't find that website any more. Does anybody have an idea where to find those? I remember the guys that make those brackets make light bars as well.
Old Feb 3, 2012 | 12:23 AM
Senomar_DTK's Avatar
Senomar_DTK
I bought a light bar that bolts down to those and it has 4 tabs on it for lights.
Old Feb 3, 2012 | 04:58 AM
SpecialEdJon's Avatar
SpecialEdJon
Why spend the money on brackets when you could just drill holes?
Old Feb 4, 2012 | 12:38 AM
Senomar_DTK
I mounted 4 lights so I needed the bar with the tabs that are extended out a bit, four lights don't fit if you drill holes, but if your only doing two then ,like specialedjon mentioned, that would be an easy and cheap way.
Old Feb 4, 2012 | 07:42 AM
SpecialEdJon
you can put four on there if you space them out the right way but it wont look as nice
Old Feb 4, 2012 | 07:59 AM
HammerZ71's Avatar
HammerZ71
If you can't fab some up, go to the local hardware store, Lowes, etc. and look. It amazes me how many places out there basically copy a pipe hanger or other common $2 hardware item and sell it at specialty truck/off-road places and charge stupid money for it.
I know guys who drop $35 a piece on light tabs that snug around grill guard bars that are just a buck and a half pipe bracket that someone powdercoated.
But I guess there's an a$$ for every seat, as they say...
Old Feb 4, 2012 | 09:02 AM
C-RAM's Avatar
C-RAM
I was thinkting of simply drilling holes but those brackets/tabs would bring the lights a bit closer to the grille and probably would make them a bit more effective.
I might just see if I can fab something from a piece of flatiron.
Old Feb 4, 2012 | 10:10 AM
Bent's Avatar
Bent
Unistrut and spring nuts...
Old Feb 5, 2012 | 09:49 AM
C-RAM's Avatar
C-RAM
What do you mean by that?
By the way... Pinawa? Nice. I have lived close by for a while.
Old Feb 5, 2012 | 07:57 PM
kvsmith2004's Avatar
kvsmith2004
Just drill the holes yourself...
