Torque Management Modification
Old Feb 12, 2012 | 08:48 PM
pumpkin hill ram's Avatar
pumpkin hill ram
Default Torque Management Modification
I have a 04 2500 fwd hemi with the 545rfe transmission. Truck has 68000k on it and is in great shape. I recently changed plugs,wires,pcv,tranny fluid and filters. The truck has a soft 1-2 up shift. I have read about the torque modification procedure which involves cuting a wire from tcm to pcm (green and yellow wire?) Can I do this mod with my truck? Just looking to firm up that shift. Thanks
Old Feb 12, 2012 | 08:57 PM
HammerZ71's Avatar
HammerZ71
Nope, because of the way the PCM operates this only works on the '03 Hemi. You would need a programmer (Strongly suggest a Superchips for an '04 PCM) to cut torque management...
Old Feb 12, 2012 | 09:12 PM
PRADO's Avatar
PRADO
Is there any programmers out there that modify the trans tcm as well on the 03 hemi? i really dont like cutting or messing with factory wiring.
Old Feb 12, 2012 | 10:49 PM
MikeHTally's Avatar
MikeHTally
Not enough market for a single-year programmer. Our '03s are the red-headed step-children.
Old Feb 12, 2012 | 11:11 PM
PRADO's Avatar
PRADO
That sucks, so no programmer that fix these sorry spongy tranny's? guess ill think about cliping that wire then. Isnt there some type of upgraded valvebody that actually makes the tranny shift better, quicker and firmer?
Old Feb 13, 2012 | 03:11 AM
abarmby's Avatar
abarmby
Don't clip the wire.
Trace the wire back to the large multi-plug on the back of the firewall.
Remove the large plug, by unbolting the small 8mm bolt I think it is from memory.
You can then open up the plug and using a very small watch makers screwdriver, slide the driver down the side of the pin to release the locking tags on it. The wire then pulls out from the back of the plug easily.
If you do it this way, any warranty you may have will be OK as you can always replace the wire back into the plug and no one will be the wiser.
I've had this done to my 03 for over 4 years now and although it doesn't solve the lazy sloppy way in which our auto-boxes usually work.....on WOT on the 1-2 and 2-3 shifts....it's a whole different ballgame
Al.
Old Feb 13, 2012 | 10:40 AM
John  M's Avatar
John M
Programmers for the 03 do support the TM modification but since I already had the wire removed I can't tell you how close it gets. Go ahead and remove the wire from the harness -- it's easy -- but you'll never want to put it back
Old Feb 13, 2012 | 09:46 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
However, getting a Sonnax Trans line booster will firm those shifts up on an 04
Trust me, I got one
Old Feb 13, 2012 | 10:42 PM
PRADO's Avatar
PRADO
will it do the same for an 03?
Old Feb 13, 2012 | 10:44 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sonnax wont work on 03. TMR mod is for that
