Head lights
Old Feb 12, 2012 | 11:56 PM
wheeler1949's Avatar
wheeler1949
Default Head lights
I had to replace both headlights on 2003 dodge ram 1500 entire head light assembly.I now have a problem with headlights not shining very far up the road even on brights still not good at all.I have done all the adjusting i can to raise but does not help.The bulbs came with headlight assembly but look the same as other will it help to change to a different bulb also both headlights are aftermarket which i purchased new for $40.00 each. Thanks for any help
Old Feb 13, 2012 | 12:05 AM
Dudemanbrother's Avatar
Dudemanbrother
If they are the halo style aftermarket headlights it is a very common problem. The only way to get good light output on those assemblies is to use an hid kit. For the money you have to spend on a quality hid set, you might be better off trying to sell your current lights and buying an oem set. Sorry to hear your new lights suck.
Old Feb 13, 2012 | 11:18 AM
wheeler1949
Default Headlights
Dudemanbrothers---Thanks for the reply
Old Feb 13, 2012 | 11:31 AM
bigdaddyII's Avatar
bigdaddyII
My uncle bought halos for his truck and noticed the same thing. they are 85% better. The halos use a weenie H1 bulb that doesn't generate much light at all.
Old Feb 14, 2012 | 12:13 PM
wheeler1949
Default Headlights
Big Daddy your response confuses me a little what do you mean by they are 85% better what is 85% better & is the halo the bulb or the entire headlight assembly.would you recommend me getting a different bulb & putting in this same assembly i have or do i need to get 2 new headlight assemblies.Thanks for your help
Old Feb 14, 2012 | 04:04 PM
dirtydog's Avatar
dirtydog
Moderate User
HID's are not meant for halogen projector lamps. They can even be worse in some instances as far as light output where the light needs to be. Since HID bulbs are longer than the halogens made for the projector lens, they cause lots of strayed light to illuminate areas you dont need.
If you already purchased the lights and are trying anything to get better output, then thats one thing but to buy them with intentions of having great ouput, you'll be sadly mistaken to find out that's not the case.
That "weenie" H1 bulb still shoots out 1400Lumens of light. The standard 9006 bulb only puts out 1000Lumens which is what Chrysler uses for most of their cars. Now, going from the H13(1100Lumens for low and 1700 for high ) you'll notice a small difference, but to say the H1 sucks is not true. It's better than most other car bulbs. It's the Projectors that suck!
Last edited by dirtydog; Feb 15, 2012 at 12:50 AM. Reason: H13 is only 1100 on low, not 1700 as I posted. means H1 is MUCH better
Old Feb 14, 2012 | 05:13 PM
Bent's Avatar
Bent
Here are some bulb types, and their comparative relative output.
http://www.danielsternlighting.com/t...ulb_types.html
Old Feb 14, 2012 | 06:40 PM
Brandon Anderson's Avatar
Brandon Anderson
Since you said you only paid $40/ea for the housings, we're all assuming you bought cheap projector headlights, but--while it may be a safe assumption--you still haven't told us what type of headlights they are. Can you post some pics, or a link to the item where they were purchased? Might be easier to help you if we know exactly what you're dealing with.
Old Feb 14, 2012 | 11:05 PM
wheeler1949
Default Headlights
Can someone look at these headlights from www.autopartswarehouse & tell me if this is what i need. Part#--HD-JH-DR02-AM-BK Thanks for all your help.
Old Feb 15, 2012 | 12:55 AM
dirtydog's Avatar
dirtydog
Moderate User
Link is bad. ---> http://www.autopartswarehouse.com/sk...gs+Best+Seller
Those are Blacked out stock type headlights and will get you better ouput than cheap projectors ever will.
I also corrected my post above, that the H13 output of 1100lumens as compared to H1 which is 1400-1550 Lumens. So, H1 bulbs put out half again as much light as stock bulbs. Shows how crappy halogen projectors actually are.
Sorry OP, not tryin to burst any bubbles...
Bent, that's the same Bulb chart i bookmarked a year ago and lost it when I changed computers...haha Thanks for it back. ;-)
