Recall leter from Chrysler. 06 Ram 2500
Subscribe
Feb 14, 2012 | 10:56 PM
If your signal lights are wonky, ie you activate right signal and left lights up on the cluster and out side the truck, or if you activate left and right lights up, thiers a recall in canada, not sure if this applicable in the States, and you get a extension on warenty to 240,000 km 0r ten years on signal lights only.
as funny as this sounds Im not making this up.
I have othier issues I need adressed, like seat foam and no right headlight so I will contact chrysler canada
Reply 0
Feb 15, 2012 | 11:36 PM
Got that same letter today. Good to know but I wish they would add the tipm to the warrenty as you will find out if you get them to troubleshoot your headlight. Assuming its not just a simple burnt out bulb.
Reply 0
Feb 16, 2012 | 12:40 PM
I posted about this a long while ago... its not an actual recall, as that they would have everyone with that part, regardless if its a problem, come in and have it replaced/repaired.
https://dodgeforum.com/forum/3rd-gen...xic-truck.html
The above link has the NHSTA references... again... no recall, just an fyi of an extended warranty on the part.
Reply 0
Subscribe
