will 325 60 20 nitto terra grapplers fit
Old Feb 15, 2012 | 07:34 PM
2008dodgeram1500's Avatar
2008dodgeram1500
Default will 325 60 20 nitto terra grapplers fit
I found a really cheap set of brand new tires and there 325 60 20. Right now I have the stock 275 65 20 tires on my truck with eagle 079 wheels. There -12 offset. Would those tires work with just a 2.5 or 3 inch leveling kit without spacers? I plan on adding a 3 inch body lift later on down the road when I can get some more money but right now I can afford adding the leveling kit and the tires. Would that work?
Thanks
Cody
Old Feb 15, 2012 | 09:18 PM
dirtydog's Avatar
dirtydog
Moderate User
https://dodgeforum.com/forum/3rd-gen...dodge-ram.html
Old Feb 15, 2012 | 09:46 PM
2008dodgeram1500
Thanks for the link ive read that probably like 4 times and I still just dont understand it lol I must be missing something. Also my wheels are 20x9
Old Feb 15, 2012 | 10:10 PM
NoLimitzR1's Avatar
NoLimitzR1
Is run 305 50 20 on a two inch level
Old Feb 15, 2012 | 10:19 PM
Dudemanbrother's Avatar
Dudemanbrother
325s are almost 13" wide. The stock +20mm rims allow for 11" tires. -12 offset sticks the wheel out just over an inch allowing 12" wide tires. I think you will need spacers. Being 325 60 makes them 37" tall so a 3" lift is necessary, a level won't give you enough hight.
Old Feb 15, 2012 | 10:45 PM
63T-Bolt's Avatar
63T-Bolt
I had these same size tires, Toyo open country a/t's under my 02 4x4 on the stock ram 20's. No lift or anything!!!!
They fit, but rub the sway bar when trying to go to full lock, not real bad but it's noticeable.
Old Feb 15, 2012 | 11:39 PM
2008dodgeram1500
I did a tire calculator on the interent and it said its a 35.35 and 12.8 wide. Im almost positive I can clear them Im just worried about them rubbing really bad. Once I put my new wheels on they stuck out a little more on the stock tires so thats what has me nervous.
Old Feb 16, 2012 | 12:33 AM
2008dodgeram1500
In your pic is that the 325 60 20 tire on the truck? If so they dont look to big on it at all.
Old Feb 16, 2012 | 12:38 AM
Dudemanbrother
whoops accidentally calculated 22" wheels. So a level will work but spacers are still needed.
Old Feb 16, 2012 | 08:57 AM
63T-Bolt's Avatar
63T-Bolt
Yes that is a pic with the 325's on it. The 305/55/20's they replaced are in the bed.
Trust me they are big! I sat them next to my friends 37x13.5x20 Toyo open country m/t's and they were about an inch shorter at most.
The rear of the truck rubbed more than the front did, the tire would touch the wheel tub when hitting a ramp at an angle. Only time I really noticed it was when I had a car on the trailer and was backing into where I live. Nothing bad just noticeable.
Like I said..... MY TRUCK IS 100% STOCK. That's no leveling kit, no spacers, nothing.....
