A/C clutch?
Old Feb 20, 2012 | 11:32 AM
hillbilli's Avatar
hillbilli
Originally Posted by bigdaddyII
Okay, I have 13.72 volts at the connector going to the compressor with the air wide open. I was unable to "jump" the compressor itself because I dont have the right connectors here for the spade connections. Also, to correct my original post about the pressures being equalized at around 115, I checked again and the high/low side is equalized at 70. Is that too low?
You have voltage going to the compressor so it should be on; also, the pressures wont change until the compressor is on.
Mopar a/c clutches have a history of sticking. With vehicle running and a/c on max, tap the the a/c clutch with a wooden handle to see if it engages. Dont use metal becuase it is a magnetic clutch and it could grab on to the handle and throw it. If it engages your clutch is sticking or broke.
Old Feb 20, 2012 | 04:40 PM
bigdaddyII's Avatar
bigdaddyII
I tried to tap it but couldnt get much leverage as the fan would hit the stick. I did get a few good whacks on it though and it doesnt move. I can turn it by hand when the engine is off, I havent tried (and wont) with the engine on though. I ordered a new compressor with clutch, accumulator and orifice tube and that will be installed hopefully Saturday.
Old Feb 26, 2012 | 07:23 AM
bigdaddyII's Avatar
bigdaddyII
Okay so it was the compressor. Apparently the coil went bad, but there is no way to change just the coil, so yesterday I put in a new compressor, accumulator, and liquid line with orifice tube and after a 1.5 hour vacuum and recharge all is well.
