Need to replace Tone Ring
Old Feb 26, 2012 | 04:33 PM
Lifttruck's Avatar
Lifttruck
Hopefully you checked your backlash before you pulled your third member. When you install a new one or re-install the old one using the existing gearset (ring and pinion) the backlash should be set to the same setting as you originally had. This insures as close to identical gear contact pattern as possible.
Old Apr 16, 2012 | 04:13 PM
JDG103's Avatar
JDG103
Default How much its going to cost to fix my axle tone ring
ok so i called a known shop here in my area, and i talked to the mech. and i told him that the axle tone ring needs to be replaced. he had asked if i had the parts which i told him i did. he said since the gears have to come out it would be a great idea to replace the seals and bearings. so im ok with that. he gave me a total labor cost of $325. i was wanting to know from you guys if this seems like a fair price.
Old Apr 16, 2012 | 04:58 PM
BlueMountainMike's Avatar
BlueMountainMike
Seems kind of low to me. How many hours did he say it would take him? I would think it would take at least 3 or 4 min to drain it... remove axles... take out carrier.... remove ring gear... clean everything thoroughly........replace tone ring.... replace all bearings - races - and seals...and then get it all back together and adjusted correctly. It's not a particularly easy job. And that time estimate is if everything goes right and no snags.. know what I mean. I just did this a couple of months ago.
Old Apr 16, 2012 | 09:21 PM
JDG103's Avatar
JDG103
yea i know what you mean...he didnt tell me how long....i would imagine it would take one day to do it...but this shop has a good reputation here where im at...but i know there might be some others out there
Old Apr 17, 2012 | 08:35 AM
dirtydog's Avatar
dirtydog
Moderate User
Tone ring replacement. I could do that on my back in the driveway in about 3hrs and includes replacing the axle seals and axle bearings. He is NOT going to replace your carrier bearings or your pinion bearing FYI at that price, which is fine because then he'll have to check backlash and pinion depth..etc. There is no shimming involved for just the tone ring. carrier out/carrier in kinda thing.
Now, make sure he knows how to adjust the pre-load as it needs to be released to pull the carrier out(unless he's just going to force it out?..bad)
This requires a special spanner tool/wrench that goes inside the axle tubing to tighten or loosen. http://extremecustomparts.com/i-3611...ol-yt-a06.html
Whats wrong with your tone ring that it needs replacing? Are there teeth broken off or something? Have you changed the sensor ontop of the housing?
Old Apr 18, 2012 | 07:34 PM
JDG103's Avatar
JDG103
i replaced the sensor and it still had the same problem....so i went and took off the diff cover and notice that my tone ring is missing teeth...i have no idea how that could have happened...but the mech told me that you have to take out the gears to get to the tone ring..if i knew how to backlash i would attempt this myself
Old Apr 18, 2012 | 10:08 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Lots of vids on Youtube on how to install and check setup if you feel froggy
Old Apr 18, 2012 | 10:50 PM
dirtydog's Avatar
dirtydog
Moderate User
Do you have stock LSD? Maybe it spit out a retaining clip? I'd deal without ABS if it was my truck. That's all the tone ring is good for. Unless the integrity of the ring is compromised by a crack or some sort.
Here's one cheap btw
Old Apr 19, 2012 | 07:00 AM
JDG103's Avatar
JDG103
Thanks weed...dirty yea i have the stock lsd...i know that i have to replace it because its making my speedo hop while im driving...and also i belive here in TX are brakes have to work with no brake light or abs light coming On the dash
Old Apr 19, 2012 | 07:48 AM
dirtydog's Avatar
dirtydog
Moderate User
Yeah, did some research and looks like speedo only goes by tone ring. I thought it had 2 sensors to go by...nope.
