Leveling kits??
Old Feb 25, 2012 | 04:30 PM
croga001's Avatar
croga001
Default Leveling kits??
Ok so does anyone on here run the coil spacer leveling kits? I know you need a n allignment after but will this lead to premature wear on the other suspension components? Any help much appreciated!
Old Feb 25, 2012 | 09:39 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Any lifting or dropping CAN cause wear or stress. But it all depends also. Not every truck wears the same. Im at 83k and just now needing to change my ball joints. But at 83k it might not be lift related. It could just be mileage and age related.
Old Feb 26, 2012 | 11:04 PM
croga001's Avatar
croga001
gotcha it also says you can clear 33's with them so maybe ill get a set and check it out
Old Feb 26, 2012 | 11:47 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, 33s are easy to clear
Old Feb 27, 2012 | 09:42 PM
croga001's Avatar
croga001
Seems like a lot of people on this forum are talking about leveling kits. Sounds like the main theme is dont run them unless you want problems down the road. I dont know, I suppose its food for thought.
