slight ticking at startup, exhaust manifold question
Old Feb 28, 2012 | 01:58 PM
ckapp's Avatar
ckapp
Exclamation slight ticking at startup, exhaust manifold question
Hi, so I've been getting a ticking, diesel engine kind of sound from my 08 4.7 engine when it is cold and poking around online led me to check out the exhaust manifolds. Well, the thing I noticed was that the drivers side has a piece of metal covering the manifold and that the passenger side does not. Also where it bolts to the pipe looks kind of warped. The sound does seem to come more from the passenger side.... Recommendations? The truck i bought used at 36000 miles, would the 5 yr 100k powertrain warranty cover this? I am going to take a few shots down there and post them shortly, thanks in advance for any help!
Old Feb 28, 2012 | 02:44 PM
MoparMan1991's Avatar
MoparMan1991
I suppose it would, but my 2001 4.7L ticks too for a couple minutes at start up too. I just threw in a bottle of Lucas Oil Treatment and it quieted it down for me. I had the same problem on a 2001 5.0L in my Explorer and used the Oil Treatment and it went away completely.
Old Feb 28, 2012 | 02:50 PM
ckapp's Avatar
ckapp
here are a few shots of the passenger side exhaust manifold
Attached Thumbnails slight ticking at startup, exhaust manifold question-photo02281322_1.jpg   slight ticking at startup, exhaust manifold question-photo02281323.jpg
Old Feb 28, 2012 | 03:24 PM
MoparMan1991
Yeah. It looks like aged metal to me. The metal cover was only a heat shield, but you know it is no big deal seeing how the headers can actually get red hot sometimes. If anything, you may have a vale problem or maybe a cam tensioner problem or something. The ticking for the 4.7L is a normal thing and almost every single 4.7L produced makes the noise.
Old Feb 28, 2012 | 03:42 PM
ckapp's Avatar
ckapp
Well if it is that common I guess I'll try the fuel treatment, and just keep an eye on it in case it starts sounding louder. Really, it isn't that loud now but i want to catch a major problem early on if possible.
Old Feb 28, 2012 | 07:12 PM
HammerZ71's Avatar
HammerZ71
check the rear two bolts on the manifold, both sides. Common problem with the 4.7 is that the bolt heads snap off - common symptom is that you hear it clanging/knocking whatever at startup, if it's not too bad yet (warped) then as heat builds, the gasket swells and the sound either stops or lessens.
Had to just do the rear two driver's side bolts on my Grand Cherokee (4.7), luckily there was enough threads exposed to get ahold of them and back them out easily...
Old Sep 21, 2012 | 07:31 PM
ckapp's Avatar
ckapp
I wanted to update on this, I did check awhile back and found one of the drivers side manifold bolts was so loose that i could remove it with my hand. I torqued it to 18 ft lbs, and although the ticking is still there, maybe not as loud as before.
Old Sep 21, 2012 | 08:45 PM
MountainmanMike's Avatar
MountainmanMike
I had the same issue with a Jeep Commander. found the pass rear exhaust manifold bolts broken off. was able to extract the broken bolts and replaced them. The noise did get quieter but didnt completely go away so I did end up replacing the gasket. Heads up If you end up replacing the gasket spend the 20 bucks and get new exhaust manifold bolts from mopar. I have seen people reuse the bolt and had the bolts break a few months down the road
