2006 Ram 3500 problems...
Old Sep 21, 2012 | 09:20 PM
nancyh1980's Avatar
nancyh1980
Default 2006 Ram 3500 problems...
Inherit this truck from my dear uncle. But this Ram truck is killing me. I love the engine. But….
For the past 3 years, when it rains, I have leaks on both sides of the A pillars (water dripping from the oval clip-on cover). Dodge dealers have not been able to locate the leak. I guess leaks and losing hub caps are unresolved problems with this model.
I hope you can help with (1) major issue and (1) minor issue.
Major:
My driver head light is out. High beam works. Changing to newer bulb, same issue. Should I run a common wire between the passenger head light (working) and the driver? Or any suggestion?
Minor:
I have separate driver and passenger seats. The center console has 2 latches: the lower one for the lower compartment and the top one for the top compartment. The bottom one is broken. Any idea of part number?
Thanks so much for your time and help.
