4.10 gear questions
Old Feb 28, 2012 | 08:44 PM
mattg34's Avatar
mattg34
Default 4.10 gear questions
hello all! i have a couple gear questions hoping someone could help me with. i own a 2005 dodge ram 1500 2wd hemi currently with 3.55 limited slip. my buddie is going to install richmond 4.10 gears, i also purchase the complete install kit from summit. are there any "heads up" concerns i should be aware of? will this change my spedometer? im currently running superchip 91 octane. if the spedo will be off can i fix this with the programmer? should i change the shift points? if so to what? nice place to have to come ask questions! thank for any and all help!
Old Feb 28, 2012 | 09:23 PM
SLT8's Avatar
SLT8
No speedo change needed and follow manuf' for break in method. I felt a good difference when going 3.55 to 4.10 but wish I went straight to 4.56s
Old Feb 28, 2012 | 09:52 PM
HammerZ71's Avatar
HammerZ71
Nope, no speedo change for gear changes, just tire diameter. I agree with SLT8, with a 545rfe transmission that basically has two overdrives, you can easily go into a 4.56 gearing.
Also, hope your buddy has set ring and pinions and most importantly in AAM axles, they can be a b*tch to get right.
If there is even a hint of whine you need to have them reset ASAP before they start to wear a poor pattern...
Old Feb 28, 2012 | 10:03 PM
pitbull24's Avatar
pitbull24
You need to change the gearing in your SC programmer. I could not find any posted shift schedules of '05's w/4.10's but tweak it if you need to.
Old Mar 11, 2012 | 10:13 PM
mattg34's Avatar
mattg34
got the gears finished up today. ran through richmonds break in procedure, no noise vibration or wierd sound! hat off to my buddy for getting it right, hes only 19 with a bright future in mechanics! ordered a pair of caltrac traction bars for a 4"flip kit. one last question what camshaft would i be able to run with superchips, aem intake, longtube headers, no cats? thanks again for all your help!
