Water Pump
Old Mar 8, 2012 | 03:49 PM
ff2011's Avatar
ff2011
also what do yo think of the pre mixed antifreeze thanks
Old Mar 8, 2012 | 08:25 PM
NV290's Avatar
NV290
Originally Posted by ff2011
my warrenty ran out
If your truck is an 08' with 76,000 miles, your warranty has definatley not run out. Are you the original owner?
will be working on it I am in the north country and will be in a mechanic bay dont know if there is a water hose in there anyway thanks
A garden hose is not madatory to do a flush. You can just fill the radiator with water using a bucket for the flush.
Old Mar 8, 2012 | 08:27 PM
NV290's Avatar
NV290
This is the only version of Pre-mix you can use in your truck: http://www.drillspot.com/products/35...freeze_Coolant But i would not waste your money on the pre-mix. You can buy full strength G-05 for less then $20.00 and dilute it yourself.
Old Mar 8, 2012 | 08:37 PM
NV290's Avatar
NV290
I called the dealer he said he never heard of h.o.a.t antifreeze
That is bizzare, considering it's the only coolant Chrysler uses in pretty much every car they currenty make.
He said it was all about color I told himm it was the chrysler antifreeze so what color is h.o.a.t thanks
Whoever you talked to should be fired. Color has NOTHING to do, at all with what coolant to use. And anybody who thinks that way knows nothing about engines and has no business working in the industry.
Case in point, Dex-Cool is Orange and H.O.A.T. is Orange and they are NOT compatible.
Old Mar 9, 2012 | 08:35 AM
DodgeCares's Avatar
DodgeCares
I called the dealer he said he never heard of h.o.a.t antifreeze He said it was all about color I told himm it was the chrysler antifreeze so what color is h.o.a.t thanks
FF,
Hopefully you were not talking to someone in service. If you were, I would be looking for another dealer.
Old Mar 9, 2012 | 08:57 AM
ff2011's Avatar
ff2011
yeah he was in service said he had never heard any of those names said all about color and my truckk is a 2007 I called checked the vin and all I had was the 3year/36000 and I am the third owner thanks
Old Mar 9, 2012 | 11:43 AM
abarmby's Avatar
abarmby
HOAT MUST be used in our trucks.
Also, HOAT has come in at least two colours that I have seen and used...Straw coloured yellow/amber and bright almost fluorescent red/pink.
Do it right the first time and forget about it.
Al.
Old Mar 9, 2012 | 07:05 PM
ff2011's Avatar
ff2011
ok so I got the waterpump changed I just used the moper antifreeze it was red the guys dont know nothing bout the hoat stuff none of them had heard of any off that stuff all they knew was colors thanks
Old Mar 10, 2012 | 04:54 AM
abarmby's Avatar
abarmby
Look on the package on the coolant.
Somewhere it should say G-05 and also somewhere Chrysler MS-9769.
If those numbers are there....it's HOAT coolant.
I've just been through all this over here in the UK, where my local Chrysler dealer due to the tie up with Fiat...has ran out of the stuff and it would have been months before getting it back in due to Fiat. I had to source another supply.
HOAT = Hybrid Organic Acid Technology and this coolant has an inhibitor package which is slightly different from traditional high-silicated green coolant, enough that it’s expected to provide double the service life, but is still compatible with traditional.
Hope this helps?
Al.
