Leaking fluid from differential where the drive shaft enters
Old Mar 8, 2012 | 10:56 AM
rosco305999's Avatar
rosco305999
Default Leaking fluid from differential where the drive shaft enters
Does anyone why I would be leaking fluid here? If so, what part do I need to replace and how would I replace it?
Old Mar 9, 2012 | 12:53 AM
jasonw's Avatar
jasonw
Site Moderator
Model year of truck? Details like trim level, engine, 1500/2500/3500, etc.?
Thank you!
Old Mar 9, 2012 | 08:18 AM
rosco305999
Ram 1500
5.7 hemi
4x4 SLT
Old Mar 10, 2012 | 11:55 PM
jasonw's Avatar
jasonw
Site Moderator
Moving you to the right section...
Old Mar 11, 2012 | 08:17 AM
boosted-fc3s's Avatar
boosted-fc3s
Sounds like the pinion seal. The part is cheap, but swapping it is a pain. Its very common for it to leak.
Old Mar 11, 2012 | 09:38 AM
SLT8's Avatar
SLT8
Agreed. Mine had sprayed around the heat shield and pumpkin. New seal and good to go.
Old Mar 11, 2012 | 10:21 AM
rosco305999
I have been getting spray in the same area! Thank you for all of your help everybody!
