Using both a strut leveling kit and a coil/spring spacer
I have looked around and found nothing. Maybe someone on here can give me a good answer. Can you add a coil/spring spacer if there is already a strut spacer installed? I have a hell bent steel 2.5 already on the front and it would be cool if I could add another 2" and then add blocks in the rear. Would you have to get a steering extension along with other extension because of the lift? Any help would be great. Thank you for reading.
No. You can't do both. If you want to go higher you need to bag the spacers and get a real suspension or body lift. Suspension lift would be the best choice but if you don't mind relocating your bumper and trying to line up your bed a body lift will get the look.
