Help me please !!
Old Mar 24, 2012 | 04:53 PM
frenchbee2306's Avatar
frenchbee2306
Default Help me please !!
my truck won't start after remove and put back the #20 fuse named IGNITION UNLOCK START/RUN
is it the anti theft system ?
lights, windows, wipers are ok
what can I do ?
thanks
Old Mar 24, 2012 | 10:39 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Check battery? Check fuse?
Does the engine turn or rotate when you turn the key or does nothing happen at all?
Old Mar 25, 2012 | 06:34 AM
frenchbee2306
issue solved !!
when I put back the fuse, I pushed away the contacts inside the box....so no more continuity in the circuit...then I fixed the contacts with a very thin flat screwdriver
now everything is OK !
thanks anyway for your reply Weedahoe
Old Mar 25, 2012 | 07:48 AM
HammerZ71's Avatar
HammerZ71
It happens, I've done it before. Glad to know all is well again...
