06 Ram Help from Canada
Old Mar 26, 2012 | 12:19 PM
Schaelc's Avatar
Schaelc
Default 06 Ram Help from Canada
Hi Fellas,
I am writing for some advice on replacement parts for my 06 Ram 1500 QC 4x4. As shocking as it may sound this early in the trucks life I need new tie-rods and ball joints. Do any of you have some high quality aftermarket suggestions that I can request my mechanic to use?
Also, I have a fair bit of shake when i brake and I think my rotors may be slightly warped. Is there any recommendation for aftermarket rotors and pads that I should consider?
Finally, I am going to get 20" KMC XD Rockstars in black (any suggestions on where I can find a great deal?) and a wheel alignment and hopefully with all this work done my truck should be like new! I will send pics once it is all done.
Thanks in advance for all the help!
Old Mar 26, 2012 | 03:42 PM
MoparPaul's Avatar
MoparPaul
As for ball joints I would go with Moog brand w/the grease fittings...that way you can maintain them periodically and they will last a lot longer than OEMs.
Old Mar 27, 2012 | 04:03 PM
dodgeboy1979's Avatar
dodgeboy1979
Where in Canada are you from eh? You may be able to have your rotors machined down to correct a slight warp rather than replace them
