pac C2R CHY4 Wiring
Old Mar 30, 2012 | 08:02 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by itsahemi4x4
What would you recomend? I realy don't want to splice the amp harness after the amp. If I ran speaker wire to all four doors right off the new deck instead of through the factory amp, then I'd lose the 3 speakers in the dash correct? How much of a difference would it make sound wise if I got nice speakers for the doors? I could go with components I guess. UGH! Stupid infinity system. Too many questions!
Using just the doors with good after markets wont make much difference. Now if you had two trucks to compare side by side you might notice a difference but for you, it wont matter
Old Apr 1, 2012 | 12:22 PM
itsahemi4x4's Avatar
itsahemi4x4
Weed, these are the wires I'm having difficulty understanding from the interfaces instructions as my Kenwood does not have those input wires available. Highlighted in Red.
11 pin plug (to CAN INTERFACE):
Blue/White - Connect this wire to the radio’s amplifier remote output. Connect this wire with or without OEM amp
1. present! This connection is VERY IMPORTANT! Some of the C2R-CHY4 features will not function if this wire is not connetced!
White/Green - SWC output. 2.
Green - Connect this wire to the radio’s reverse input wire only. 3.
Orange/White - Connect this wire to the radio’s Illumination input wire only. 4.
Violet/White - Connect this wire to the radio’s VSS input wire only. 5.
Red/White - Connect this wire to the radio’s parking brake input wire only. 6.
Not sure if I need to wire these, and if so, where do I find them and what colors are they? Your help is greatly appreciated.
Old Apr 1, 2012 | 12:32 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Check out this site as it will help
http://www.the12volt.com/installbay/vehicles.html
Reverse wire and VSS are under the hood and in the PCM harness.
Reservse is a white with green strip
VSS is a green wire with yellow stripe
Again, these are knly needed for navigational units as nav requires these for GPS.
Old Apr 1, 2012 | 01:32 PM
itsahemi4x4
does that apply to the parking brake as well?
thanks again.
Old Apr 1, 2012 | 01:34 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Parking brake wire apploes to both navigation AND dvd playback so you might wanna use it.
Old Apr 1, 2012 | 02:01 PM
itsahemi4x4
I just paid visit to Pioneer's website. SInce I don't have DVD or Nav, I don't need any of the three wires. Those wires are inputs for nav units, but on any non-nav or DVD stereo, they are not used. Thanks for your help. I can't wiat to get this thing installed. Think I'm gonna install the radio first and see how it sounds with the factory speakers. If I like that, I'll roll with that setup. If I don't, then I'll get some new 6x9's for the front, and run them off the radio directly so I get fll range sound to them.
Old Apr 1, 2012 | 03:31 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You didnt believe me? LoL
Post pics when you get all done
Old Apr 1, 2012 | 03:51 PM
itsahemi4x4
I believeed you, just doing some more research and stumbled on the info. Thanks for all you help, and I will post some pics if I can ever figure out how.
Old Apr 1, 2012 | 04:06 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I know bud, I was just teasing you but I still think you will need the brake wire in order to play DVD while driving.
Old Apr 1, 2012 | 06:36 PM
itsahemi4x4
Thanks for all of your help. BTW, nice truck. So, by using this interface, I'm still sending all of my signal through the Infinity amp correct? If I later decide to run everything off of the Kenwood through an aftermarket amp, how or where would be the best place to run the speaker wires to since it seems as though running any wires into the doors themselves would be impossible.
