03 RAM 1500 2WD 2.5" Lift and Shocks
Old Apr 2, 2012 | 09:03 AM
areinike's Avatar
areinike
Default 03 RAM 1500 2WD 2.5" Lift and Shocks
I basically threw these on this weekend.
Threw in? I wish ... was a bit more of a pain that anticipated, but nonetheless, they're in, truck sits nice and level and the ride isn't bad at all. Seems about the same.
My questions is, because it's lifted about 2-2.5" should worry about new shocks. I've contemplated getting 2500 2WD shocks as they're a little longer - but would the extra length cause the upper A arm to hit the frame or does anybody have any issues with that?
Alignment, well, I need new tires, ball joints yadda so I'll get all that done later. So far, It rides pretty straight puling ever so slightly to the right ... of course, could be the road, too - our roads are a little rounded for drain off I suppose.
Old Apr 2, 2012 | 12:29 PM
MikeHTally's Avatar
MikeHTally
Unless your shocks are bad, you don't need to replace them. When it comes time to replace them, you can use the stock size.
You do need to get an alignment. Unless you want to buy tires sooner, go ahead and get the alignment done.
Old Apr 2, 2012 | 01:31 PM
areinike's Avatar
areinike
Thanks, Mike. It rides fine the way it is and don't notice anything out of the ordinary other than it looks so much nicer leveled.
Old Apr 2, 2012 | 02:35 PM
areinike's Avatar
areinike
Just out of curiosity .. I looked up some specs on like models of some Monroe shocks. To be safe, looks like the 4WD 1500 shocks would be a good "cushion" with the lift ... when the time comes The 2500 mounting seems a little different, but should still work. Any thoughts? Note, I just picked a model of Monroe for comparison purposes.
2003 Dodge Ram 1500 RWD (STOCK)
PN 32390
Upper Mounting Code Stem Mount - 3.5/16" Stem Length X 5/8"-11 Thread Pitch
Lower Mounting Code Cross Pin Mount - Closed Ended, 5/16" Hole ID (Both Ends) X 2.7/8" Pin Length (Hole Center to Center)
Compressed Length 9.875"
Extended Length 14.250"
Travel Length 4.375"
Dust Shield Yes
Parts Pack(s) P1167
Compressed Bumper Stop No
Extended Bumper Stop Yes
Extended Hydraulic Lockout No
Compressed Hydraulic Lockout No
Dust Shield Material Metal
2003 Dodge Ram 1500 4WD
PN 32392
Lower Mounting Code Loop Bushing& Sleeve Mount - 9/16" Sleeve ID X 1.5/8" Sleeve OAL
Compressed Length 10.750"
Extended Length 15.875"
Travel Length 5.125"
Dust Shield Yes
Parts Pack(s) P1167
2003 Dodge Ram 2500 RWD
PN 32400
Upper Mounting Code Stem Mount - 2.5/8" Stem Length X 1/2"-13 Thread Pitch
Lower Mounting Code Cross Pin Mount - Open Ended, 3/8" Hole ID (Both Ends) X 3.3/16" Pin Length (Hole Center to Center)
Compressed Length 11.000"
Extended Length 16.375"
Travel Length 5.375"
Dust Shield Yes
Parts Pack(s) P1167
Extended Bumper Stop No
Old Apr 2, 2012 | 02:40 PM
areinike's Avatar
areinike
scratch that. 1500 4WD won't work, just realized. the bottom mount is differnt - DOH!
Old Apr 2, 2012 | 02:51 PM
areinike's Avatar
areinike
hell, the more I look the more confused I am, screw it. Stock shocks are fine. lol
Old Apr 2, 2012 | 09:06 PM
MikeHTally's Avatar
MikeHTally
I did a 2 1/2" level on mine in '07. Just changed the shocks to Monroe Reflex last year @ 111K.
