Aeroforce Wideband O2 install question
Old Apr 8, 2012 | 04:27 PM
T-Muns's Avatar
T-Muns
Question Aeroforce Wideband O2 install question
I picked up an aeroforce interceptor gauge and it's pretty sweet. I also found a lightly used wideband kit to go with it. The wideband controller box calls for (2) 12v ignition on sources.
Does anyone know if I have to run 2 fresh wires from the fusebox or can I just splice into existing ones under the dash?
Instructions
a. Connect the red wire to a switched (ignition on) positive 12 volt source.
b. Connect the white wire to a switched (ignition on) positive 12 volt source.
c. Connect the black wire to a ground source (the wire going to pin 5 of the
OBD2 port is a good source for signal ground but not required. It may
eliminate the rare instance of a small error due to differences in ground
potentials).
Old Apr 8, 2012 | 06:54 PM
SpecialEdJon's Avatar
SpecialEdJon
Theres a switched ignition wire under the dash thats 12v u can tap into it should be pink with a yellow strip
Old Apr 8, 2012 | 08:22 PM
T-Muns's Avatar
T-Muns
Thanks. I think I'm going to splice them both into one of the cig lighters.
Old Apr 8, 2012 | 08:41 PM
SpecialEdJon
i wouldnt do the cig lighters. its not very safe. The wires under the steering column are assery wires witch are safer to tap into.
Old Apr 9, 2012 | 08:42 AM
NV290's Avatar
NV290
What's wrong with tapping the cig lighter wires? My radar detector and fog light switch (relay) have been there for years.
