is this a busted bearing seal ??
Old Apr 14, 2012 | 12:20 PM
rentprop1's Avatar
rentprop1
Default is this a busted bearing seal ??
came home after a 100 mile trip today to find the right ( pass ) front tire looking like this, smells like burnt oil......
not sure it if matters much but I had a tire rotation done about 3 days ago, but didn't notice anything till today ?? could it be spilled coffee or something ??
2005 Ram 1500 SLT 4.7 with 97 K if that matters
Old Apr 14, 2012 | 01:29 PM
hillbilli's Avatar
hillbilli
4x4 or 4x2? Tire shop could have used a solvent to loosen lug nuts or something. Wheels look pretty clean, have you recently gotten a car wash? It almost looks like mud.
Old Apr 14, 2012 | 09:08 PM
rentprop1's Avatar
rentprop1
4 x 2 , I hear you about the solvent, but its only on the RF wheel ??
Old Apr 14, 2012 | 09:41 PM
freestyledude's Avatar
freestyledude
If it was 4x4 I was gonna say it looks like CV grease.
Probably worth your time to pop that wheel off and take a better look at where that grease is coming from. Remember to use a torque wrench when you put it back on, I had a few lugs walk out recently from using a cold torque wrench
Old Apr 15, 2012 | 02:08 PM
rentprop1's Avatar
rentprop1
took the wheel off today and it appears to be something that was sprayed on the outside of the wheel cover, like a solvent to loosen the lug nuts
good call hillbilli
now for the bad news looks like I found a bad lower ball joint boot while I was under there ....arrrgh
Old Apr 16, 2012 | 09:09 AM
hillbilli's Avatar
hillbilli
Glad it wasnt anything major but it sucks about the ball joint. At least you found it before it eats up your tires. Be sure to replace it with a good greasable ball joint like Moog and you should be set for a few more years.
