Turn signal problem!
Old Apr 15, 2012 | 01:33 PM
Dimeblack1's Avatar
Dimeblack1
Default Turn signal problem!
Can a keyless remote cause my front directional signal to fail?
I have a 2003 Dodge Ram 2500. I have been having a problem with my front passenger turn signal not working. a friend and i have followed the circuit to the keyless remote module. This seems pretty weird! Could this be the problem? or did we not go far enough? Part number #P56045755AB
Old Apr 16, 2012 | 10:10 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will move your post to the 3rd Gen Ram section.
Old Apr 17, 2012 | 08:28 AM
dirtydog's Avatar
dirtydog
Moderate User
I'm wondering if you are having a problems with your underhood fuse panel. They are notorious for corossion on the underside because they are not protected from the elements of weather. The corrosion can cause all kinds of wierd things.
That's where I would start to look. More than half that have electrical problems find the fuse box corroded and have to dissassemle, clean and lube.
