3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
What type of sensor did you use for the thermostat? The screw in type(if so where does it go)? The one that goes thru the rad.? Or, the one that gets inserted in the hose?
Radiator probe. If the price isn't bad next time I want to try a sensor that taps into the heater core hoses so it is the coolant temp not the radiator (it's a bit delayed)
The radiator probe that came with the kit did not work for me. I bought the sensor that screws into the bung on the engine coolant outlet, and the fan has been keeping the temps spot-on at my setting ever since. Couldn't be happier.
