Spark Plug change needs
Old May 7, 2012 | 03:14 PM
08HEMI1500's Avatar
08HEMI1500
Default Spark Plug change needs
I'm now at 34XXX miles and now that its summer and I have alot of time on my hands I figure it's a good time to get in there and change the plugs. I know I need 16 copper plugs and apparently some garden hose according to Hammer haha. But what else should I be getting? Swivel sockets? I'll be on a kinda tight budget so if you know the cheapest route of getting this done right I'm all ears. And what about the coil packs? Do I need to change wires in these or the whole pack or can whatever is there stay? Thanks in advance as always guys.
Old May 7, 2012 | 03:19 PM
Willy McNasty's Avatar
Willy McNasty
I changed my plugs a few weeks ago. Basically I used the 10mm sockets to get the caps off then for the plugs themselves I just used two 2" extensions on a 3/8" ratchet. The two separate extensions allowed me to get in there to the tight spaces. You may want some grease & air to blow off the thing before you take the plugs out.
Old May 7, 2012 | 06:00 PM
vinman966's Avatar
vinman966
Yes and have a massage all lined up for that evening too.
Plan on most of the morning or afternoon to get it all done.
Old May 7, 2012 | 07:08 PM
MikeHTally's Avatar
MikeHTally
An extra-long plug socket helped me a bunch. It sticks up out of the plug well an inch or so. I got mine from Harbor Freight for 'bout $5. Amazon has one, too.
Old May 7, 2012 | 11:06 PM
08HEMI1500's Avatar
08HEMI1500
I have some extensions for my sockets but I did read about swivel ones so idk if I really need them. I also did forget about the anti seize for the new plugs
Old May 8, 2012 | 08:09 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Dont we have a How To on this in our FAQs?
Old May 8, 2012 | 11:19 PM
08HEMI1500's Avatar
08HEMI1500
No sir. Not that I saw anyways. I always check from time to time to see if someone does but I guess no one is brave enough. Just A LOT of threads about this. I think my main concern is the coil pack issue since I have no clue what that means or if I should do anything about them.
Old May 8, 2012 | 11:29 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Old May 10, 2012 | 12:22 AM
cyclone429's Avatar
cyclone429
Removing the air box frees up space, it pops off two bolts in the fender ( take out air filter and you willsee it) , air inlet, c clap on TBI and out goes the air box ( also helps when getting at the right head light bulbs) under the brake booster is a bit trickey, But I did it, next go arround I will give platt plugs a try ( srt engines use platt plugs, not coper)
I'm lucky to get 40,000 km out of 16 sparkys than the mpg drops hard and the truck runs not so good...
Old May 10, 2012 | 04:04 PM
08HEMI1500's Avatar
08HEMI1500
I have a Homemade CAI so I don't even have the stock air box anymore lol
