4.7 engine cooling
Old May 10, 2012 | 07:20 PM
tafet's Avatar
tafet
Default 4.7 engine cooling
Has anyone tried to increase the size of the bypass hole in the thermostat to get it to open earlier? I'm contemplating an experiment to see if it works.
Old May 10, 2012 | 07:44 PM
MikeHTally's Avatar
MikeHTally
That won't make it open sooner. What makes it open is the temperature of the water. Increasing the hole size would actually make it open a tiny bit later (more cooling, but only a tiny bit).
Old May 10, 2012 | 07:48 PM
superdak05's Avatar
superdak05
most of us dakota guys swapped out the stat for the napa stat, 530080, its a 180 stat, truck likes to run cooler and wont toss a code
Old Jun 1, 2012 | 01:40 PM
tafet's Avatar
tafet
I've gotten the 180 t-stat. The top end still comes in at 200 degrees. I was thinking that enlarging the bypass hole by a few thousandths to see if the t-stat will open a little earlier.
