Tire size verse speedo error-More question
Old May 15, 2012 | 10:52 PM
ldj1002's Avatar
ldj1002
Originally Posted by itsahemi4x4
Were the 20's the original wheels. If not, they could have been giving you a false reading, and now your reading the correct speed. Those RPM's seem pretty high. What engine and gearset do you have. When you went to the shorter tire, did the truck "wake up" at all? Dropping 2 inches of sidewall would numerically raise your effective gear ratio and may feel like the truck has a few more cojones off the line.
I don't know what size wheels were original. Because the door says 17" I suspect the 20's were not original. I don't know rear end ratio. Everyone says rpm are a little high for speed. I don't have anyway to check speedo except with another vehicle.
Old May 16, 2012 | 07:16 AM
MikeHTally's Avatar
MikeHTally
Wheel size has no effect - it's tire diameter that is key. If you look on the diff, you may find a metal tag. If it has "39" or "3.9", it's a 3.92 gear set. If so, it came with 20s. From your rpm at speed, my guess is you have 3.92s. My truck has 3.55s. With 265/70x17s, it turned 2,020 rpm at 80. Now with 285/70s, it turns 1,980.
