Tire size verse speedo error-More question
Old May 15, 2012 | 01:22 AM
ldj1002's Avatar
ldj1002
Default Tire size verse speedo error-More question
I posted other day about speedometer error if I changed from 20" wheels and tires to 17". Well I made the trade. The tires I have now are about 2" maybe a little more shorter than the 20's. I am getting exactly the same speedometer speed with a given rpm as with the 20's. 60mph=1900rpm, 70mph=2200rpm. How can that be? Looks to me I would have to have more rpm to get the same speed with smaller tires.
Old May 15, 2012 | 10:35 AM
kamicrazy99's Avatar
kamicrazy99
What are the exact tire sizes - before and after? Did you physically measure the tires to figure out that they are 2" shorter, or are you going by the tire spec?
Old May 15, 2012 | 11:48 AM
ldj1002's Avatar
ldj1002
I actually stood them side by side and measured. Straight edge on top of tall tire extended over to above short tire and measure down from there. Of course how level I had straight edge would affect the distance to short tire, but it is close.
Does the speedometer get its info from the tach via the computer? If so tire diameter would make no difference in speedometer reading, it would only make difference in actual speed. The accuracy of speedometer in that case would depend on what tire size was entered.
Another question, my truck has 17's listed on the door. Does that mean that is what was on it from factory?
Old May 15, 2012 | 03:32 PM
08HEMI1500's Avatar
08HEMI1500
You're turning 1900 RPMs at 60!? I only turn 1600. You should invest in a tuner to adjust the tire size and tune the truck in general.
Old May 15, 2012 | 05:52 PM
MikeHTally's Avatar
MikeHTally
Mine turns 1,980 rpm @ 80 mph. 285/70x17s.
Old May 15, 2012 | 05:55 PM
MikeHTally's Avatar
MikeHTally
17" is the basic stock wheel. 245/70x17 tires. Yours came on 20" wheels. What are the two tire sizes you're comparing?
Old May 15, 2012 | 06:23 PM
ldj1002's Avatar
ldj1002
I had 275/60x20 I now have 265/70x17.
How do you know mine came on 20" wheels?
Old May 15, 2012 | 07:56 PM
MikeHTally's Avatar
MikeHTally
Your first post indicated you were changing from 20" to 17". Were the 20s added later?
Old May 15, 2012 | 08:02 PM
MikeHTally's Avatar
MikeHTally
Your stock tire is probably the same as mine: 245/70x17. My 285/70x17s have made the speedometer/odometer 4.3% slow/low. If you have a GPS, it can show you how much the speedo and odo are off.
Old May 15, 2012 | 09:15 PM
itsahemi4x4's Avatar
itsahemi4x4
Were the 20's the original wheels. If not, they could have been giving you a false reading, and now your reading the correct speed. Those RPM's seem pretty high. What engine and gearset do you have. When you went to the shorter tire, did the truck "wake up" at all? Dropping 2 inches of sidewall would numerically raise your effective gear ratio and may feel like the truck has a few more cojones off the line.
