08 Caliper options?
Old May 23, 2012 | 01:42 AM
Jason D's Avatar
Jason D
Default 08 Caliper options?
I was looking for a noise in my front end today and while searching I found one of the rubber boots around the piston on my caliper had rubbed through and are now allowing moisture to get in there. So my question is, are there any better calipers I can mount up to get better braking? Or do I just go buy a stocker?
90% of the time when I am using my truck it is towing a trailer and 4 motorcycles so some better brakes would be great!
Edit: its a 1500
Old May 23, 2012 | 11:13 AM
08HEMI1500's Avatar
08HEMI1500
You could look into Brembo brakes like the SRT10 has. You might want to get new rotors though too
Old May 24, 2012 | 12:26 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I literally just pulled both my front calipers off the truck, pulled the pistons out and rebuilt them with new seals. Not hard but you do need the right tools. Certainly far less than buying new calipers. I also took the time to powder coat mine myself.
