Problem with cruise control on 2006 Dodge 1500 crew 4.7l
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Mine 2006 Dodge 4.7L , When i turn on the power of cruise control and speed reached 60mph to Push the SET. the power turn off on CRUISE itself after push set. Repeat i turn on push the power wont work while driving. when the motor turn off and come back motor running Again I push the power on it work CRUSIE ligth on same as above.... so i checked the fuse are fine everything.... any hints thank for your time
Welcome to the site. Do some researching and reading but you might find it to be the wheel sensor in the front drivers side wheel bearing hub assembly.
Is ABS on wheel hub to check on loose the plug on front drive side ? Last summer I replaced Wheel Hub twice in 4 yrs and not there on abs senor plug on passager side. Thank Weedhoe
