Don't know what to do?
Old Jun 2, 2012 | 11:51 AM
Jdsgtball's Avatar
Jdsgtball
Default Don't know what to do?
Ladies and Gentlemen,
So I just bought an 02 dodge ram 1500 4 wheel drive. So my issue is the lights on the dash board started acting weird. The abs light, emer brake light, check eng lt and air bag lt come on and stay on, the speedo and AC doesn't work! Looked at the fuses and they look good just not sure where to go next? Any help would be appreciated?
James
Old Jun 3, 2012 | 05:33 AM
abarmby's Avatar
abarmby
Just a silly thing but, are you sure your battery is good?
I've had a few electrical gremins due to a bad battery before and I read of more than a few who have had all kinds of funny stuff because of a bad cell in a battery.
The electronics and stuff in these trucks, demand good batteries and charging etc.
Just a thought.
Al.
Old Jun 3, 2012 | 08:38 AM
HammerZ71's Avatar
HammerZ71
Cluster is probably f*cked...
Old Jun 3, 2012 | 12:20 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Time to download a Service Manual and do some reading and searching cause IDK what else to say at this point without referencing the FSM.
Old Jun 3, 2012 | 11:24 PM
freestyledude's Avatar
freestyledude
Cluster no good or your fusebox is very corroded. See if you can pry the fusebox open a bit and check for nasty corrosion
Old Jun 15, 2012 | 07:17 PM
Jdsgtball's Avatar
Jdsgtball
So ladies and gentlemen,
So I have a code that popped its a P0500 it says its a VSS(vehicle speed sensor). Whaere is that located? I looked through the service manual and didnt see that. Also how would that be linked with the A/C not working I can see the ABS and speedo not working. Any help will be appreciate it.
