AC blowing warm
Old Jun 3, 2012 | 09:19 AM
Gorhad's Avatar
Gorhad
Default AC blowing warm
Hi all,
recently my AC has started blowing warm, but only at a standstill. I have checked the Freon level with the AC pro kit and its fine. What I did notice is that at the front of the vehicle next to the main radiator there is a smaller radiator (I think it's the evaporator?) with a fan attached to it, protected by a 30 amp fuse in the circuit distribution box. The fuse is fine but the fan does not spin, so I tapped the motor gently and it began spinning. Could this cause the AC to blow warm?
Thanks
Old Jun 3, 2012 | 10:14 AM
Suckingas03's Avatar
Suckingas03
Yes. I had the same problem. The motor in the fan is probably going bad. I hear its a common issue.
Old Jun 3, 2012 | 10:21 AM
Suckingas03
Well atleast on 02-05 idk about your 01. Theres a 2nd Gen forum too
Old Jun 3, 2012 | 12:18 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Doesnt matter, he knows what his issue is and already identified it as the condensor fan not spinning. If he has to jump power to it to make it work then I suggest he start tracing wires and checking fuses.
Old Jun 3, 2012 | 12:40 PM
Gorhad's Avatar
Gorhad
Hi guys many apologies, just realized i hadnt changed my vehicle info, Just corrected it again many apologies i do have a 3rd gen ram
Old Jun 3, 2012 | 12:44 PM
Gorhad's Avatar
Gorhad
Update
Just fitted new fan motor (advance auto Part No. 35380 $50 bucks) and voila its blowing nice n cold again
Thanks all
Old Jun 3, 2012 | 01:45 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Im lost, if you tapped power from another source and it worked, why did you replace it?
Old Jun 3, 2012 | 01:56 PM
Gorhad's Avatar
Gorhad
weedahoe when i said tapped i meant physically tapped it with a wrench on its casing lol sorry weedahoe, i'm from England originally. Thanks
Old Jun 3, 2012 | 01:59 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
LOL....gotcha brother. The gold ole beat it with a hammer (or wrench) trick
Old Jun 3, 2012 | 02:04 PM
Gorhad's Avatar
Gorhad
lol i messed up this lil thread with my British accent, still it is the Diamond Jubilee today lmao
