3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
From: stationed in groton ct but im from gainesville TX
hey man, i had the same problem. climb under your truck and follow the wire back from the diff. and make sure the wire harness is fully connected. mine had pulled apart just a little and prevented it from locking. i just replaced the harness and everything has been fine since. see if this is your problem BC i be it is
i just un-plugged and re-plugged and it worked but i noticed the reason it came loose was the little plastic snap that held it plugged in was broke so i replaced it.
Not off the top of my head im just a hobbiest. I'm currently sitting in the middle east so research on my end is difficult but send a message to HammerZ71 he should be able to help you he is very knowledgable. sorry i couldnt help you more brother.
