Spark Plugs
Old Aug 19, 2005 | 10:13 AM
mill500's Avatar
mill500
Default Spark Plugs
I'm about ready for my 30k maint ('04 Hemi), and did a search to see what everybody's thoughts on plugs were, and it's all over the road. Other than a general consensus that nobody seems to like the multi-tips, everybody seems to disagree on brands or copper vs. platinum, etc.
The service manual says stay with Champions. Any thoughts?
Old Aug 19, 2005 | 05:42 PM
osteodoc08's Avatar
osteodoc08
Default RE: Spark Plugs
If it ain't broke, don't fix it. In other words, stick with the Champions.
Old Aug 19, 2005 | 07:07 PM
HemiBuell's Avatar
HemiBuell
Champion spark plugs have such a bad name. Most people who have worked on a lot of motors would tell you to stay away from Champion. Not saying I agree with this.
Old Aug 19, 2005 | 07:39 PM
DonG's Avatar
DonG
I would stick with the Champions as well.
Old Aug 20, 2005 | 05:52 AM
cntrsnr2001's Avatar
cntrsnr2001
I'm not sure how the coils are on the ram, but I think that if the impedence of the plugs are too low for the designed current output of the coil then you can burn it up in a heartbeat. i've had this happen on a for escort before when i used bosch platinum +4.
Old Aug 20, 2005 | 02:27 PM
aappleby's Avatar
aappleby
I just changed mine. I used Double Platnum Autolite plugs. They're a 50,000 mi plug. I've used them in an 83 monte, 96 Ranger, and a 2000 GTP. No problems what so ever. The plugs even came pre-gapped. I still checked them before I put them in.
Old Aug 20, 2005 | 07:42 PM
nukemsram's Avatar
nukemsram
I had Champions go out on my 96 Plymouth Breeze at right around 36K. The mechanic broke open the Champions and showed me why. Champions use a coil insided the plug. If that coil heats up for any reason, it could snap. The mechanic broke open a Bosch plug for me and showed me it also. Bosch uses a solid rod all the way through the plug. My Breeze has 138K on it now and I've never had a problem with the plugs since they were changed. I'll never use Champs again.
