05 Hemi - Tow/Haul vs 19ft Bass Boat
Old Jun 11, 2012 | 09:32 PM
HEMI_NOOB's Avatar
HEMI_NOOB
Default 05 Hemi - Tow/Haul vs 19ft Bass Boat
When pulling my boat (19ft Nitro 901 bass boat) should I use the tow/haul mode? I don't know it's exact weight but it should be under 3000lbs.
2005 Hemi Quad Cab 4X4
Old Jun 11, 2012 | 10:14 PM
boosted-fc3s's Avatar
boosted-fc3s
I would, just to save the excess wear and tear and the tranny from it hunting for OD.
Old Jun 11, 2012 | 10:15 PM
HammerZ71's Avatar
HammerZ71
I pulled a 19' Javelin bass boat with a 175 HP on it, full of gear all over the southeast for tournaments the first two years I had my truck. Only time I used tow/haul was pulling the mountains of north Georgia/Tenn and western NC...
Old Jun 12, 2012 | 06:36 AM
jrsick's Avatar
jrsick
If you are on level roads and can maintain a steady speed then OD works good. Otherwise it won't make much difference anyway so you might as well turn it off.
Old Jun 12, 2012 | 11:36 AM
HEMI_NOOB's Avatar
HEMI_NOOB
For the most part, Indiana is flat. There is some hills in the southern part of the state but nothing too extreme.
Old Jun 13, 2012 | 09:18 AM
04HemiGreg's Avatar
04HemiGreg
In significantly hilly our mountain type areas, i would use tow/haul. On fairly flat roads, i probably wouldnt. When i tow, its usually a heavy rv and i always use tow mode. But i have towed boats on occasion and cargo trailers with golf cart, atv, or dirt bikes on it and for stuff like that, i dont use tow mode unless i feel like the tranny is straining. After owning the truck for years and towing quite a bit with it, i can sort of tell when something is straining it or not. It is very flat where i live so i can usually get away without tow mode for lighter loads.
