Unknown Wires
Old Jun 16, 2012 | 02:57 AM
Cdaddydodge's Avatar
Cdaddydodge
Default Unknown Wires
I have a few pics that i wanted to post for myself and anyone else that may have no idea what these wires are and/or do. I wanted to tap in to them with my fog lights but no power...or is there??? SO here they are, 1st and 2nd are the same with/out the cap, 3rd is right under the drivers head lamp and i will get another one that i saw afterward which is near the A/C (bottle? Tired sorry) enjoy!!! Sorry for the size of the pics, also if anyone wants better pics, let me know!!I would love to tap in to these. Cheers!!
Old Jun 16, 2012 | 08:47 AM
Kscha41's Avatar
Kscha41
The second pic looks like the temp sensor that mounts by the drivers headlight. The third pic looks like the harness for the factory fog lights to plug into.
Old Jun 16, 2012 | 09:35 AM
dirtydog's Avatar
dirtydog
Moderate User
The first pic is unplugged of the 2nd pic if I understand correctly? That is your Ambient air temp sensor for your overhead readout. It should be mounted to the Driverside headlamp on the lower bolt that is located behind the grill when hood is down. If you take the bolt out and put it there, you'll see the indented outline. The plug would be situated ontop with the sensor pointing downward. It's suppose to catch fresh air outside the truck as your driving down the road and while idling rather than hot engine heat if left behinf the radiator.
The 3rd pic is of the factory foglight harness. If you have a 2002-2005 you have power and simply need to hook up your fogs to them and they will work. 2006-2008 needs the circuit to be turned on by a dealer for the circuit to work.
Old Jun 16, 2012 | 12:06 PM
Cdaddydodge
Perfect!! I had a feeling it was the harness for my fogs but when testing for power and ground i got nothing ( when the lights were turned on/off) When i do get my fogs will i have to buy a different switch as opposed to the one already in the truck or are they automatic like day time running lights?
Ok so this air temp sensor, if it were to just dangle or become to close to "Heat" would this affect throttle response, air intake or what not? I think i will mount it back were it goes lol.
Thank you guys very much for this, much appreciated!!!
Oh and yesw DirtyDog the first 2 pics are the same. With the cap out ( temp sensor)
Old Jun 16, 2012 | 09:48 PM
Kscha41's Avatar
Kscha41
You would have to see if your headlight switch pulls out. On our trucks, in order to turn the fogs on, you have to at least trun the parking lights on, then you pull on the switch to turn the fogs on. If your switch donesn't pull out, you will have to replace it with one that does.
Old Jun 17, 2012 | 01:42 AM
Cdaddydodge
Ahh cheers! I'll have to try that, if not...i'll just throw in another switch or run it with my day time lights. I'll look into that switch, im sure it's bloody expensive at the stealer-ship, but ebay may have one.
Old Jun 17, 2012 | 07:59 AM
SLT8's Avatar
SLT8
Part # 82209437 for OEM Fogs for trims that have the pre-wired setup.
Pic of how the ambient sensor should be installed.
