hub assembly
Old Jun 20, 2012 | 01:06 PM
tafet's Avatar
tafet
Default hub assembly
I'm looking for more of a confirmation here for what I want to do. Replacing one of my hubs and the f er is frozen in the spindle. I've gotten a bigger hammer to try again. When I put the new on in I want to put a coat of antiseize around the inside of the spindle where the assembly mounts. Its not a rotation point so I think it'd be fine. What says the crowd?
Old Jun 20, 2012 | 02:26 PM
p38251's Avatar
p38251
yes. some PB blaster may help get it apart. Anti-seize the splines on the axle shaft. Not alot, alittle bit goes a long way. Good luck
Old Jun 20, 2012 | 08:58 PM
tafet's Avatar
tafet
Thanks. I was going to let someone else do it after my first attempt failed. After the $400 price quote, I figured I'd give it another shot..
Old Jun 20, 2012 | 11:57 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
2wd or 4wd? If a 2wd and you have the 3 bolts off the back of it that holds it to the spindle and nothing else is holding it in place, I would go the hammer route or the air chisel.
Same thing on a 4wd assuming you have the CV out of the way
Old Jun 24, 2012 | 11:37 PM
tafet's Avatar
tafet
I have the 2wd. It took awhile, but I beat lolly livered "F" out of it. It finally came out though. Took a 3lb hammer and a pry bar..
Old Jun 26, 2012 | 12:12 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well at least progress was made
