outside cablight question?
Old Jun 23, 2012 | 10:35 PM
catawissarocket's Avatar
catawissarocket
Default outside cablight question?
on my 05 my outside rear cab light only comes on if i switch it on from inside. i though if you open the door it should come on? I've rotated the dimmer switch and still wont work unless i turn the dimmer switch up until it comes on.. maybe it doesn't suppose to come on when opening the door?
Old Jun 23, 2012 | 11:12 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
It should come on when you unlock your door if your truck has factory key-less entry. If you do have key-less entry and it doesn't do it then I think you will have to do some kind of procedure to change the truck's settings
04HemiGreg's Avatar
04HemiGreg
I've never noticed if mine comes on when I open the door or not. Mine does come on, though, if it's locked and I unlock it with the keyfob.
Old Jun 24, 2012 | 10:09 AM
catawissarocket
I dont have keyless entry,the only time it comes on is if i manually do it..
anyone else have any info on what i can do??
Old Jun 24, 2012 | 11:07 AM
hyperjay's Avatar
hyperjay
Mine is the same as 04HemiGreg. It won't come on when I open the door, but it does come on if I lock or unlock with keyless entry.
Old Jun 24, 2012 | 07:41 PM
p38251's Avatar
p38251
Not sure if it changed 2004. L side lights when open D/S door. R side lights when Passanger door opens. Both sides light up when I hit keyless entry. Hope this helps.
