rough idle, no power
hey guys, i have an 02 dodge ram 4.7 4x4. yesterday truck wouldnt start and check engine light came on once started. I had 4 coil packs go bad and a misfire on a cylinder that had a bad coil pack. Today, i replaced the bad coil packs and all of the spark plugs and it still is running rough w/ not much power. when i test drive it, it dies when i come to a stop. so i decided to check the fuel injectors with an ohm meter, set on 200 ohms
#2...25.2
#4...23.4
#6...no data (not enough time to move wires around)
#8...no data " "
#1...24
#3...18.5
#5...34
#7...17
now, i dont know what these results mean as i cant find any info as to what the resistance is supposed to be, but it seems as they might play a small part in whats going on. any info would be great...thanks for your time.
#2...25.2
#4...23.4
#8...no data " "
#1...24
#3...18.5
#5...34
#7...17
thx...i have downloaded the manual, it will be a huge help. However, new problems have come about...i now have new error codes p0351-0356../sigh, does that sound like pcm issues? btw...i will still go through and test all the wires
