What is this part?
Old Jun 24, 2012 | 10:47 AM
pizza442's Avatar
pizza442
Default What is this part?
Got my oil changed at the dealership in my '06 Ram and found this under the hood just sitting on top of the radiator..?
Old Jun 24, 2012 | 01:17 PM
HemiLonestar's Avatar
HemiLonestar
Goes under your oil cap, the end with the hole sits up.
Old Jun 24, 2012 | 01:21 PM
pizza442's Avatar
pizza442
Wow, really? Goes down into the fill tube? What purpose is it there for and why did the tech pull it out and leave it on my radiator?!
Old Jun 24, 2012 | 05:58 PM
HemiLonestar
Why he left it out, I'm guessing airheadedness, mental retardation or just plain carelessness. Goes like this:
It was band-aid fix TSB because the 4.7 has always had emulsion/condensation issues, which seems to be a common theme with the newer engines with those high fill caps (my hemi has it).
Form TSB-003 Rev. 1.08 February 3, 2000
NUMBER: 09-01-00 Rev A
GROUP: Engine
EFFECTIVE DATE: Sept. 11, 2000
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 09-01-00, DATED
FEB. 18, 2000, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A
COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT
REVISIONS.
SUBJECT:
Foamy Oil Emulsion Accumulation Inside The 4.7L Engine Oil Fill Housing
OVERVIEW:
This bulletin involves the installation of a baffle and a revised oil fill housing cap.
MODELS:
2000 (AN) Dakota
2000 (DN) Durango
1999 – 2000 (WJ) Grand Cherokee
NOTE: THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH A 4.7L ENGINE.
SYMPTOM/CONDITION:
A customer may complain of an oil emulsion accumulation inside the engine oil fill housing.
The oil emulsion will normally be foamy and be gray or light brown in color.
The emulsion accumulation will often occur on cooler engine surfaces, like the inside of the
oil fill housing. Modern engine oils are designed to address the oil emulsion phenomenon.
Oil emulsion accumulation is normal and will not damage the engine
A new baffle and a revised oil fill housing cap have been released. The baffle and oil cap
will help to reduce the amount of oil emulsion accumulation within the oil fill housing.
DIAGNOSIS:
If the customer has experienced this issue, then perform the Repair
Procedure.
PARTS REQUIRED:
1 53032126AA Baffle, Oil Fill Housing
1 53032389AC Cap, Oil Fill Housing
REPAIR PROCEDURE:
1. Remove old oil fill housing cap.
2. Remove any foamy oil emulsion from the inside of the oil fill housing with a clean
cloth.
Old Jun 24, 2012 | 06:13 PM
pizza442's Avatar
pizza442
Interesting since my Ram is an 06 with the V6...musta been set down on mine by accident while the hood was up. Seems that this thing is obvious when installed so I would have seen it the times I changed the oil myself..
Old Jun 24, 2012 | 07:53 PM
dirtydog's Avatar
dirtydog
Moderate User
They take it out so to use a pump gun or funnel with ZERO restriction. That piece restricts flow and makes a mess if you fill too fast. Allows you to dump wideneck oil bottles down super fast with it removed. I dont have one on my '08 and oil goes down super quick.
It's there more or less to prevent get this... the "sight" of oil emulsion, what we know as sludge. It's a ridiculous remedy to mask an emulsion problem so the customer cannot see the issue, thus making them feel better.
The things they come up with are unreal. Leave it out. It's pointless.
Old Jun 24, 2012 | 09:44 PM
HemiLonestar
Your V-6 is a derivative of the 4.7 (3.7 = 4.7 - 2 cylinders + more stroke). My wife's Liberty had it and my Ram had it (had to look up a pic online since I couldn't take one for you).
X2
Old Jun 26, 2012 | 11:29 AM
pizza442's Avatar
pizza442
I knew the 6 and 8 were brothers but wonder why the TSB didn't include the V6 and only mentioned the V8. Either way I thank you for the answer. Now I wonder if anyone would actually buy this thing on Ebay....!
Old Jun 26, 2012 | 09:41 PM
HemiLonestar
Because the TSB is dated 2000, about 2 years before the 3.7 was available...
